4570Man
Super Star Member
- Joined
- Apr 7, 2015
- Messages
- 18,484
- Location
- Crossville, TN
- Tractor
- Kubota M59, Kubota L3800, Grasshopper 428D, Topkick dump truck, 3500 dump truck, 10 ton trailer, more lighter trailers.
Is a longer hydraulic cylinder stronger than a shorter cylinder with the same diameter, same side rod, and same psi? I have seen several hydraulic output calculators and most only take the diameter of the cylinder and the rod diameter into account.
Does a 12" long 3" cylinder with a 1" rod at 2500psi push exactly the same power as a 36" 3" cylinder with a 1" rod at 2500psi?
