Hydraulic cylinder problem
   / Hydraulic cylinder problem #1
donnyviking
rochester mn
MF 451 FWD
I just changed hydraulic lines on a top link cylinder. The cylinder is connected with QDs at the tractor. The cylinder will lift an implement but immediately loses pressure (implement is lowered). Of will loft fine bit will not stay up. No visible signs of leak. Engine RPM is high enough for lifting. I assume there must be an air pocket in the cylinder?? If do, how do you bleed the line.
   / Hydraulic cylinder problem #2
With the engine off...try operating the valve lever in both directions and then disconnect and re-connect the hoses...
Thanks Slash. This did the trick. For my education, the disconnect and reconnect must allow air to escape?
   / Hydraulic cylinder problem #4
Honestly I'm not sure what it does but it always seems to work...Normally air will bleed out on its own through the system...even when replacing hoses etc...
2006 Mercedes-Benz E350 Sedan (A51694)
2006 Mercedes-Benz...
UNUSED RAYTREE RMSC78-78" SOIL CONDITIONER (A51248)
UNUSED RAYTREE...
2018 Kia Soul Crossover SUV (A51694)
2018 Kia Soul...
1838 (A51248)
1838 (A51248)
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
Lot of 2 Caterpillar Loader Tires (A51691)
Lot of 2...
