Hydraulic Cylinder for 3 point
   / Hydraulic Cylinder for 3 point #1
jon edwards
Lewistown, Montana
Case Farmall 75C, john deere 1520, Polaris 900 XP
A friend of mine suggested that I get a hydraulic cylinder for the top pin of my three point. It looked like a pretty good idea to me. Does anyone have any advice or experience with a set up like that?
   / Hydraulic Cylinder for 3 point #2
Search the terms HTL (hydraulic top link) and TnT (Top and Tilt) for lots of reading. Do you have a remote on your tractor to operate it?
Thanks for the information. My tractor has one remote with a splitter, so I could use that setup and still have one remote for an implement. I'll research that some more. Would it help to have a quick attachment for my tractor?
   / Hydraulic Cylinder for 3 point #4
Depends on your age, as the older you get, the harder it is to swap implements, but if you only swap once a week, etc, then save your money. If you change frequently, it will probably help.
Remember not all q/c are the same.
Thanks. I googled HTL and TnT. Looks pretty interesting. I think that the HTL will work well for me. I'm going to look for one to buy. Thanks for the help. If you buy a HTL, do you just take it off if you don't have an implement on the tractor?
   / Hydraulic Cylinder for 3 point #6
Or just let it hang as long as it doesn't interfere with anything.
David from jax
   / Hydraulic Cylinder for 3 point #7
Search the terms here on TBN as well-LOTS of reading! I have the iMatch QH so the HTL stay's on all the time.
Other search terms (for here on TBN) include:
CCM
DPOCV
   / Hydraulic Cylinder for 3 point #8
I didn't want mine dangling and bouncing around back there when not in use. So on my open station tractor, I hooked a long rubber tarp strap between the ROPS hinges. It holds the HTL up at about a 60 degree angle just fine. No exposed ROPS on on my cab tractor, so I just use a shorter strap hooked to other locations of convenience.
//greg//
Thanks, I'm using a tarp fastner now to hold up the top hitch. I wondered if that would work with a clyndiner.
   / Hydraulic Cylinder for 3 point #10
I have a solid rubber tarp strap that I have one end looped around the ROPS and I put the cylinder rod in the hook on the other end. I do not suggest this if you have steel hooks, though.
UNUSED LANDHONOR LHR-AIW1-1" AIR IMPACT WRENCH (A54757)
UNUSED LANDHONOR...
2000 CATERPILLAR 140H MOTOR GRADER (A51406)
2000 CATERPILLAR...
2008 KALMER 4X2 SPOTTER TRUCK (A51247)
2008 KALMER 4X2...
2840 (A54757)
2840 (A54757)
(NEW) 2025 DOWN 2 EARTH GOOSENECK TRAILER (A51247)
(NEW) 2025 DOWN 2...
2021 CATERPILLAR D4 LGP CRAWLER DOZER (A51246)
2021 CATERPILLAR...
