Hydraulic Cylinder for 3 point
   / Hydraulic Cylinder for 3 point #1
jon edwards
Lewistown, Montana
Case Farmall 75C, john deere 1520, Polaris 900 XP
A friend of mine suggested that I get a hydraulic cylinder for the top pin of my three point. It looked like a pretty good idea to me. Does anyone have any advice or experience with a set up like that?
   / Hydraulic Cylinder for 3 point #2
Search the terms HTL (hydraulic top link) and TnT (Top and Tilt) for lots of reading. Do you have a remote on your tractor to operate it?
Thanks for the information. My tractor has one remote with a splitter, so I could use that setup and still have one remote for an implement. I'll research that some more. Would it help to have a quick attachment for my tractor?
   / Hydraulic Cylinder for 3 point #4
Depends on your age, as the older you get, the harder it is to swap implements, but if you only swap once a week, etc, then save your money. If you change frequently, it will probably help.
Remember not all q/c are the same.
Thanks. I googled HTL and TnT. Looks pretty interesting. I think that the HTL will work well for me. I'm going to look for one to buy. Thanks for the help. If you buy a HTL, do you just take it off if you don't have an implement on the tractor?
   / Hydraulic Cylinder for 3 point #6
Or just let it hang as long as it doesn't interfere with anything.
David from jax
   / Hydraulic Cylinder for 3 point #7
Search the terms here on TBN as well-LOTS of reading! I have the iMatch QH so the HTL stay's on all the time.
Other search terms (for here on TBN) include:
CCM
DPOCV
   / Hydraulic Cylinder for 3 point #8
I didn't want mine dangling and bouncing around back there when not in use. So on my open station tractor, I hooked a long rubber tarp strap between the ROPS hinges. It holds the HTL up at about a 60 degree angle just fine. No exposed ROPS on on my cab tractor, so I just use a shorter strap hooked to other locations of convenience.
//greg//
Thanks, I'm using a tarp fastner now to hold up the top hitch. I wondered if that would work with a clyndiner.
   / Hydraulic Cylinder for 3 point #10
I have a solid rubber tarp strap that I have one end looped around the ROPS and I put the cylinder rod in the hook on the other end. I do not suggest this if you have steel hooks, though.
SCAN FOR HAULING AND FINANCING INFORMATION (A52706)
SCAN FOR HAULING...
23110 (A53424)
23110 (A53424)
2014 Ford F-550 4x4 Crew-Cab Flatbed (A52377)
2014 Ford F-550...
2017 FORD F150 REG CAB LONG BED 4X4 (A54313)
2017 FORD F150 REG...
2015 Kia Cadenza Sedan (A53424)
2015 Kia Cadenza...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
