Hydraulic Cylinder Drawing/CAD Model?
   / Hydraulic Cylinder Drawing/CAD Model? #1
avc8130
Platinum Member
Northern, NJ
Kubota L45
Does anyone know where I could find technical drawings or even a CAD model of a hydraulic cylinder that would be suitable for use on a grapple? I'm working on designing a grapple in Pro/Engineer and I really want to be able to put the cylinder in my model to check for range of motion and to make sure I don't get any interference.
ac
   / Hydraulic Cylinder Drawing/CAD Model? #2
Have you browsed GrabCad.com?
   / Hydraulic Cylinder Drawing/CAD Model? #3
If you have a supplier in mind it would be best to ask them. that way you know what you will be getting and that it will fit correctly. If you are going thru all the CAD design parts then for it to actually work correctly you need the model from the company supplying/building the cyl.
I dont know if Surplus Center has cad models but they supply part numbers of cylinders they have available and manufacture so then go after the manufacture for a model off a download or sales & support from their site.
Mark
   / Hydraulic Cylinder Drawing/CAD Model? #4
I have used the drawings from Surplus Center many times to create my own models. They should have all the information that you need.
Oh wow, I've never seen that site before.
I realized now I need to pick a cylinder first as they don't seem to be 100% universal.
Any suggestions for a cylinder to base my grapple design around?
I don't know what diameter or stroke is commonly used.
ac
   / Hydraulic Cylinder Drawing/CAD Model? #6
ac
The cylinders on my grapple are 2 1/2" with 8" stroke.
   / Hydraulic Cylinder Drawing/CAD Model? #7
Use a cylinder meeting ASAE dimensional standards. Most grapples do, and you are assured of always finding cheap, commonly available replacements.
You know, I had wondered if there was some sort of standard for exactly this reason.
Any links to an example?
ac
   / Hydraulic Cylinder Drawing/CAD Model? #9
   / Hydraulic Cylinder Drawing/CAD Model? #10
you could go directly on Parker web site than make your with the spec you need than download it!
Manac Walking Floor Trailer (A50322)
Manac Walking...
8ft Fork Extensions (A51691)
8ft Fork...
TMA (A49461)
TMA (A49461)
JOHN DEERE 408R (A53084)
JOHN DEERE 408R...
2017 Nissan Titan Crew Cab Pickup Truck (A51692)
2017 Nissan Titan...
2001 International 4700 Dump Truck (A51691)
2001 International...
