Hydraulic Coupler
/ Hydraulic Coupler #1
Believer
I have a Deere 6210. One of the hydraulic couplers will a) pop the coupled hose out on pressure and b) blow fluid out under pressure--like a quart in a couple seconds, high pressure. Are other any simple things to look for? Can I rebuild the coupler or should I buy a new one, its about $90.
/ Hydraulic Coupler #2
I would buy a new one and be done. But thats just me.
/ Hydraulic Coupler #3
I was going to tell you to try and wash the coupler out with a can of brake clean but the fact that you lose about a quart of hydraulic fluid suggests that the ball in the coupler isn't sealing it off when the male end pops out. You could relieve the pressure in the coupler and push the ball in with a wooden dowel and see if there isn't some debris stuck in there. the debris might also be keeping the coupler from gripping the male end to hold it in place the way it was designed to do. If you can't find anything them your best bet is to replace the coupler. Also check the male end against a known good one and see if there is any wear on it.
/ Hydraulic Coupler #4
Some manufacturers have rebuild kits.
Who made the coupler, and what is the number on the QD?
Check with these guys for a replacement ser.
Quick Disconnects > Discount Hydraulic Hose.com
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
2017 Freightliner M2 106 Auto Crane HC10 5 Ton Crane Service Truck (A61573)
2017 Freightliner...
1979 AM General 6X6 Truck (A65563)
1979 AM General...
2018 F-150 4WD (A63688)
2018 F-150 4WD...
Bobcat T650 (A64126)
Massey Ferguson 573 (A64126)
Massey Ferguson...
