Loader Hydraulic Coupler - Size?
/ Hydraulic Coupler - Size? #1
maximus1277
Manchester CT
2010 KUBOTA B2320, 2010 KIOTI CK27, Kubota L3940,JD110 TLB
Ok... after 500 trouble free hours on my CK27, I have a minor hydraulic leak at the loader coupler. First, I could not disconnect the hoses for the life of me. I never removed the loader since the tractor was new, and minor corrosion plus wear on the inside of the female end (from vibration I guess) made a job which should have taken a minute, an hour worth of struggle. In case you are wondering, there was no pressure in the system... I moved the joystick all over the place. Second, I wanted to buy the female end of the hose at local stores, but no place has the exact fit to match the male end sticking out of the bracket on the tractor. The o-ring inside is definitely damaged, and so is the inside of the coupler.... I know the hose end is 3/8, but what else should I know to order one of these on-line? the nearest dealer is 2 hours away... any other suggestions? I appreciate it.
Thanks....looks like the 3/8 they have at the tractor supply... But it wouldn't fit.
/ Hydraulic Coupler - Size? #4
Try 1/2
/ Hydraulic Coupler - Size? #5
Download the coupler chart on that page.. Cross check against the chart or show me a very clear close up picture.
I suspect they will be ISO 7241 either A or B And they should be 3/8 in that size.
Here are the pics.... I went to a nearby bobcat dealer, and they didn't have it as well. I was shocked!
/ Hydraulic Coupler - Size? #7
Call your dealer. Give him a credit card number. Wont that work?
I found it at a local hydraulics place: Parker 6601-6-6 PHK is the part number in case someone needs it. Thanks for your help!
/ Hydraulic Coupler - Size? #9
Yes OK that is an ISO 7241-1 series A 3/8 inch size
Which is what I thought it would be.
/ Hydraulic Coupler - Size? #10
Thats one of the worlds most common QCs, found on every CUT/SCUT here for the last 30 years. How can that be hard to find?
/Marcus
/ Hydraulic Coupler - Size? #11
Yes, The Kioti/Bobcat's are the only machines I've run across so far that uses the "A" series. All other OEM's use "B" or "AG" styles.
/ Hydraulic Coupler - Size? #12
/Marcus
Sorry Marcus, most use the "B" or "AG" style.
/ Hydraulic Coupler - Size? #13
I just took the loader off my Kubota tractor today for the second time in 1100 hours. There was a lot of crud in between the fittings and two of the six required a few taps from a small hammer to dislodge this crud before they would disconnect.
/ Hydraulic Coupler - Size? #14
My new NX has 3/8 7241-1 B style.
10in. Auger Bit (A65640)
10in. Auger Bit...
2007 Ford Fusion Sedan (A64557)
2007 Ford Fusion...
New/Unused ATS T460 Mini Skidsteer (A65583)
New/Unused ATS...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2008 Ford F250XL, Crew Cab (A62679)
2008 Ford F250XL...
New/Unused 72inch Quick Attach Rock Grapple Bucket (A65583)
New/Unused 72inch...
