Hydraulic Cooler Unit Replacement
/ Hydraulic Cooler Unit Replacement #1
CBB
Just north of the PA line in NY
JD 5320N Vineyard, 1981 Deere 910, 1980 Kubota B22, 1983 Ford 1710
The Hydraulic Cooler Unit on my Kioti CK20 started leaking. This was detected because I smelled a strange odor and stopped to investigate.
I called TriCounty Supply, the Kioti Dealer in Western New York and they ordered a replacement unit under the warranty.
To replace this cooler took about 15 minutes. I filled the unit with hydraulic fluid prior to installing them. I think this helps to keep air out of the system but maybe it is not necessary. Capped off the fluid levels and good to go.
Well designed and easy to work on tractor and quick, friendly response from dealer. Can't ask for more.
/ Hydraulic Cooler Unit Replacement #2
Got any pictures, i'm not sure what your talking about. Just curious as I have a CK20 as well and don't recall seeing any cooler on mine.
Steve
/ Hydraulic Cooler Unit Replacement #3
Steve
It will be infront of the radiator and right behind the air cleaner.
It is only on the hst tractor.
It looks like a baby radiator.
ATS ME18 Mini Excavator (A64047)
ATS ME18 Mini...
2008 Unverferth 220 Rolling Harrow (A63116)
2008 Unverferth...
2016 FREIGHTLINER CASCADIA 125  T/A DAY CAB TRUCK TRACTOR (A59910)
2016 FREIGHTLINER...
Pallet Fork Extensions (A64047)
Pallet Fork...
6ft Tiller (A64047)
6ft Tiller (A64047)
SDlanch SDLGC80 (A60462)
SDlanch SDLGC80...
