Hydraulic cooler 35D
   / Hydraulic cooler 35D #1
Hoeman00
Platinum Member
N Central Ohio
NH TC35D/SUPER H&M/F-20/JD B&D/FORDSON/JD250 SSL
I was trying to mow last Wed. nite and saw a puff of smoke come out of front of tractor.
After stopping as soon as possible and opened hood to find everything from battery to cowl covered in hydraulic oil.
I could see it coming out of the top right oil cooler line.
The cooler has a crack where the fitting is welded in.
Called dealer and they have to bring the semi out to get it.
Supposed to get it last Thursday but now they say get it today.
The grass is over 8" high now so hopefully they will get it fixed soon.
   / Hydraulic cooler 35D #3
...or possibly the aftereffects of a fix of the battery corrosion problem. On mine they removed everything and replaced a lot, but the cooler was one of the items that really didn't show any damage, so that just went back on. Seems if they weren't careful, they could have overtorqued the fittings and caused some damage.
   / Hydraulic cooler 35D #4
Some of the hydraulic oil coolers have been failing on these tractors. This is not new news to New Holland
   / Hydraulic cooler 35D #6
Spencer, any particular serial numbers or things to look out for?
I'm lucky no battery corrosion at all.
Spencer what are they doing about fan interference w/ shroud?
I told dealer to check this out too.
Also having problem w/ main PTO lever, it engages ok but if u pull it out slow the handle bends and wedges in the slot.
So I usually twist handle and pull disengage in a quick motion, this works but told dealer to order a new handle and see if they can see what the problem is.
My yard is fast approaching 10" tall /forums/images/graemlins/frown.gif
CUMMINS ENGINE CO. N-855F DSL TIRE PUMP MOTOR (A51406)
CUMMINS ENGINE CO...
2014 Club Car Electric Golf Cart (A51694)
2014 Club Car...
20' Multi Door One Way Ship Container (A52384)
20' Multi Door One...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2007 Hino 268 Truck, VIN # 5PVNJ8JT072S50704 (A51572)
2007 Hino 268...
2018 CASE IH 110N LOT NUMBER 223 (A53084)
2018 CASE IH 110N...
