Chaostamer
Bronze Member
- Joined
- Jan 28, 2012
- Messages
- 74
- Location
- Viola, ID
- Tractor
- Mahindra 3215 w/ FEL & Kubota M6040 w FEL
Good point on the weight issue. I am thinking that a snow thrower and a hydraulic snow plow would work like a charm.
Thanks for the kind words, guys. Educate me (I'm now in Hydraulics 102). On my Kioti I'm not using any control valve for the snowblower, just engaging the PTO at idle and ramping up to engine speed before moving into the snow. When finished I stop, give it a little time to clear the auger and chute, back down to idle and only then disengage the PTO. Are you thinking I have a significant risk of cavitation and possible hydraulic motor damage when using this technique?
I appreciate your experience and wisdom.
DrMac
I'd like to build something like this.....some day. It takes the fluid from the loader circuit. I have most of the hydraulic parts all I need is time which is always in short supply.
Sheyenne Tooling & Manufacturing
Greetings;
I have a chance to purchase a 73" Quick Attach hydraulic snow blower that I want to mount on the front of my 47 hp. tractor.
Quick Attach informs me that I need a 15 GPM PTO pump that puts out 3000 PSI.
All of the PTO pumps I find operate at +/- 2000 PSI, which I am told will not be enough to handle much snow.
The 2000 PSI pumps sell for +/- $600 while their 3000 PSI pump sells for $4,500.00.
Has your snow blower worked well with a +/- 2000 PSI pump?
Any feedback would be much appreciated.
Thank you.
Thom
