Hydraulic controller for bucket is non functioning, will not raise or lower bucket.
   / Hydraulic controller for bucket is non functioning, will not raise or lower bucket. #1
d1r1
Princeton,MA
Montana 4340
The hydraulic controller for the bucket is non-function. There is no resistance on the controller stick; front to back. side to side the stick works fine it curls and uncurls the bucket. What can be the problem?
   / Hydraulic controller for bucket is non functioning, will not raise or lower bucket. #2
Are you saying that the lever is sitting in neutral position and the lever will not move?
Are you saying that the lever will move fwd and rev and nothing happens?
The lever moves forward and reverse and nothing happens. There is no resistance on the control stick !
   / Hydraulic controller for bucket is non functioning, will not raise or lower bucket. #4
Welcome from Wisconsin
   / Hydraulic controller for bucket is non functioning, will not raise or lower bucket. #5
Have you checked to be sure linkage is attached to spool?
   / Hydraulic controller for bucket is non functioning, will not raise or lower bucket. #6
Reset all the QD's.
Install a hyd gage and check the pressure.
Does the relief valve activate when you move the lever to full fwd or rev and hold it?
Can you see the spool moving in and out?
Remove the load check valve for the spool and inspect for damage. It mayn be in between the two work ports or on the backside of the valve.
2017 Polaris 500 Ranger Diesel Utility Cart (A53421)
2017 Polaris 500...
GMC 3500 Extended Cab 4WD Pickup Truck - 6L V8 Gasoline Automatic (A55218)
GMC 3500 Extended...
2018 John Deere 470G Hydraulic Excavator (A55787)
2018 John Deere...
2015 Chevrolet Silverado 3500HD Enclosed Service Truck (A52377)
2015 Chevrolet...
