Hydraulic controller for bucket is non functioning, will not raise or lower bucket.
   / Hydraulic controller for bucket is non functioning, will not raise or lower bucket. #1
d1r1
Princeton,MA
Montana 4340
The hydraulic controller for the bucket is non-function. There is no resistance on the controller stick; front to back. side to side the stick works fine it curls and uncurls the bucket. What can be the problem?
   / Hydraulic controller for bucket is non functioning, will not raise or lower bucket. #2
Are you saying that the lever is sitting in neutral position and the lever will not move?
Are you saying that the lever will move fwd and rev and nothing happens?
The lever moves forward and reverse and nothing happens. There is no resistance on the control stick !
   / Hydraulic controller for bucket is non functioning, will not raise or lower bucket. #4
Welcome from Wisconsin
   / Hydraulic controller for bucket is non functioning, will not raise or lower bucket. #5
Have you checked to be sure linkage is attached to spool?
   / Hydraulic controller for bucket is non functioning, will not raise or lower bucket. #6
Reset all the QD's.
Install a hyd gage and check the pressure.
Does the relief valve activate when you move the lever to full fwd or rev and hold it?
Can you see the spool moving in and out?
Remove the load check valve for the spool and inspect for damage. It mayn be in between the two work ports or on the backside of the valve.
2012 CHANDLER 130 BBL STEEL VACUUM TRAILER (A53843)
2012 CHANDLER 130...
2011 Ford Econoline Cargo Van (A55852)
2011 Ford...
2006 TerraGator 8104 (A55301)
2006 TerraGator...
2012 JOHN DEERE 333D SKID STEER (A52706)
2012 JOHN DEERE...
UNUSED LANDHONOR FW-13-15000G HYD WINCH (A54757)
UNUSED LANDHONOR...
2008 UTILITY DRY VAN TRAILER 53X102 (A54607)
2008 UTILITY DRY...
