Hydraulic control
/ Hydraulic control #1
Bbradley13!
Massey Ferguson 135 diesel
I have a diesel Massey Ferguson 135 and I bought it with the hydraulics backwards, I don’t know if it was replaced by an inexperienced mechanic or what the story is, but up is down, and down is up, figured someone had hoses or something switched, I’d like to make it right, it came with no owner’s manual or troubleshooting guide so I need to see if I have to split it, or it just something simple.
/ Hydraulic control #2
The 3pt hydraulics or loader
/ Hydraulic control #3
If you mean the bucket goes down when you push the control arm up that is the way it is supposed to be.
Bucket goes up when you pull the lever back or down - that is correct.
/ Hydraulic control
On the 3 point rear hydraulics, sorry
/ Hydraulic control #6
My guess is that the the 3pt control shaft has been flipped 180. You may be able to take the handle off and turn the shaft one way or the other to get it back correct. If not, you will probably have to take the linkage, #6 apart and flip.
