Hydraulic control valve question
   / Hydraulic control valve question #1
telephoneman
Upstate New York
John Deere H,John Deere 650,John Deere x540,International 240 Utility
I have a Ford 1210 tractor w/front mounted snowblower. It has a Metro 3 spool control valve( I didn't know what to call it, my neighbor knew) That contorls blower up/down, shute direction and shute angle. One side has control handles (3 individual) the other has the hydro in and out and 3 more aluminum caps with small holes in the center. I took one off and it has a spring showing. Now to my problem, while moving the conrol levers a small amount of hydro comes thru the hole in the cap( only 2 of them have this leak). With the help of the neighbor we replaced the o-rings in each but they still leak when the control is operated. Sorry so long with this. What would you guys do next? Any help would be appreciated.
   / Hydraulic control valve question #2
I don't know. That was the 'easy' fix that you did. What quality of O ring did you use, perhaps try some top notch O rings, not the cheapest in a box from China if that is what you tried first? On my big Ford they have a special white ring for some hyd places, the regular blacks won't hold up.
It would come down to the stem inside the O ring being worn I guess, if the O rings don't take care of it? Did you look at themfor any scratches? Also it is not too hard to pinch an O ring when you reinstall, could be that they just got damaged on the install.
Hoping to find an easy fix for you.... /forums/images/graemlins/wink.gif
--->Paul
JOHN DEERE 5075E (A53084)
JOHN DEERE 5075E...
2019 Dodge Challenger Passenger Car (A51694)
2019 Dodge...
New/Unused 12ft x 7.4ft x 8.2ft Container (A51573)
New/Unused 12ft x...
2005 FORD F-650 (A52472)
2005 FORD F-650...
2013 Dodge Charger Passenger Car, VIN # 2C3CDXAT8DH646721 (A51572)
2013 Dodge Charger...
2008 FORD F-350 (A52472)
2008 FORD F-350...
