Hydraulic connectors on TC33DA - Grainger part???
   / Hydraulic connectors on TC33DA - Grainger part??? #1
VA_Joe
Does anyone have a non-New Holland part number/model number for the hydraulic quick connectors on the TC33DA? I am looking for something generic like a Grainger part number.
Thanks.
Joe
   / Hydraulic connectors on TC33DA - Grainger part??? #2
I use a Flat-Faced connector over the standard type. They're great for keeping dust and dirt out when disconnected. I usually give a quick shot of brake cleaner and wipe them off before reconnecting. I'm not sure of the brand but similar (or same) ones are available on ebay Item number: 7550662700. Just check for proper size.
Update: I have Parker FF series.
Tazz,
From the grainger catalog (#396 on page 1564) - there seems to be three different types of couplers:
1. Safeway/Pioneer Interchange
2. FD45 Series Industrial Interchange
3. 5600 Series Industrial Interchange
Is Parker FF another type or is it one of the three listed above? Are these the "standard" skid steer connectors that one always sees?
Also - is the flat face connector interchangeable with the "standard" type or do you need to put adapters on the tractor manifold to use them.
I haven't done too much with hydraulics and am trying to make heads/tails out of all the different quick connector types.
Thanks much.
Joe
   / Hydraulic connectors on TC33DA - Grainger part??? #4
Sorry for the delay, been super busy here.
I think the fittings in Grainger are Aeroquip (MFR) and are most likely not interchangeable with the ones you have. I would by a net M/F set.
Likewise, flat face fittings are not interchangeable with other styles. I just prefer them over the std. because they are easier to clean
When buying new hydraulic fittings make sure the thread is the same on the connector as the fitting thats compressed on the hose, and the connector is rated for the proper pressure.
Maybe someone else can help with the specifics. I'm no expert. on this.
   / Hydraulic connectors on TC33DA - Grainger part??? #5
Here is a link to a cross reference for quick couplers. Just choose the series that you want to compare. Most tractors use 4000 series couplers.
Quick Coupler reference
Thanks much for the link. The large number of different connector types makes it all confusing. Now I have something to work with. Thanks again.
Joe
   / Hydraulic connectors on TC33DA - Grainger part??? #7
Most ag machinery comes with a very, very, standard Pioneer coupling these days.
When I had rear hyd ports added to my 1720, the kit has some smaller fittings. I tossed them, and went with the bigger univeral female connectors. There are several different male connectors that fit these, some can be used under pressure, etc.
I'm not sure if new CUT style equipment comes with this smaller 'standard' fitting, or the regular ag stype Pioneer univeral?
If you will only have one or 2 of your own implements, then go with whichever style you want to use.
Since I have 5 tractors & a couple dozen implements with hyd connectors, _everything_ is going to conform to that Pioneer Universal ag port. /forums/images/graemlins/smile.gif
--->Paul
New Wolverine Skid Steer Forks Attachment (A53002)
New Wolverine Skid...
2023 FORD F-250 SUPER DUTY (A52472)
2023 FORD F-250...
2021 KOMATSU D39PX-24 CRAWLER DOZER (A51246)
2021 KOMATSU...
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A52748)
GALAXY - SET OF...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2018 INTERNATIONAL BOX TRUCK (A52472)
2018 INTERNATIONAL...
