Hydraulic Connectors for Tractor Heater
   / Hydraulic Connectors for Tractor Heater #1
PoleClimber
South Central Pa.
TC 35A
I have a heater for my cab that I take out every spring and install every fall. Would it be possible to use hydraulic quick connetors adapted to the cooling system and heater so the heater could be removed without removing hose clamps and plugging the ends.I have a ball valve on the line to shut down the circulation when its not in use. Does anybody have any experience with this or some other ideas I could consider.??
Bernie
   / Hydraulic Connectors for Tractor Heater #2
Also, there are similar connectors that I use on my garden hose that should work just as well. Might be better with the lower psi involved with the water system. I'd primarily be concerned with good, unrestricted flow of the hot water.
   / Hydraulic Connectors for Tractor Heater #3
   / Hydraulic Connectors for Tractor Heater #4
</font><font color="blue" class="small">( Would it be possible to use hydraulic quick connetors adapted to the cooling system and heater so the heater could be removed without removing hose clamps and plugging the ends..... Does anybody have any experience with this or some other ideas I could consider.??)</font>
Yes, to both questions. Except you can use water connectors especially made for water lines instead of hydraulic connectors...much cheaper.
I use these components on the water cooling and heating systems for plastic injection molds. They make several types of quick disconnects that either thread into or onto pipe or have barbed ends to put into hoses with hose clamps. You may have to call them if you don't see exactly what you want. Or get 2 pipe nipples per hose, attach the quick disconnects (male and female) and put the pipe nipples into each end of the hose. Connect or disconnect the hoses when you want.
Go to THIS LINK to view the product. They are called Jiffy Connectors from the DME Company. Other plastic injection mold supply companies carry them as well.
Hope that helps answer your questions.
   / Hydraulic Connectors for Tractor Heater #5
I use air line connectors for the heater hoses for my cab. When my cab is removed, I just short circuit the water line as shown in the attached photo. When I have the cab on, I attach the supply end to the input side of the in-line fuel pump visible at the bottom of the photo. The supply hose to the cab attaches to the output end of the pump and the return hose from the cab attaches to the lower hose connection. The in-line pump eliminates the need to bleed the air out of the circuit to the cab. There is minimal fluid loss when changing over either way. I think valved connecturs such as hydaulic fittings might be too restrictive for heater hose connections, ie not enough pressure to get an adequate flow. /forums/images/graemlins/smile.gif
This is exactly what I'm looking for. Thanks for all the input. /forums/images/graemlins/grin.gif
   / Hydraulic Connectors for Tractor Heater #7
</font><font color="blue" class="small">( This is exactly what I'm looking for. Thanks for all the input.)</font>
Yeah, I thought so.
Air connectors would also work but these are rated for temperate variations and also come in larger sizes to fit your needs better. Most air line quick disconnect I have are 1/4" NPT and these can go up 3/8" or 1/2 NPT for larger water lines. Just ask them.
   / Hydraulic Connectors for Tractor Heater #8
Have you considered just making an auxillary route? By this I mean a couple of tees & valves & you could leave it hooked up all the time, but just turn the valves to have it flow or not flow.
All you would really need is 2 valves. You wouldn't have to restrict both sides of the heater, just one to stop/start flow & one on the auxillary route to start/stop its flow as well.
   / Hydraulic Connectors for Tractor Heater #9
I forgot to ask if you leave the cab on all year or not? This would have a big impact on making something permanent.
I remove the cab and standalone heater every spring and let the heater hoses attached to the tractor with plugs in the end. I was looking for a way to remove the heater without undoing 2 hose clamps and plugging the ends.
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
Horst Quick Tach Bucket (A52349)
Horst Quick Tach...
2011 International WorkStar 7400 Chassis Truck, VIN # 1HTWGAAR1BJ325796 (A51572)
2011 International...
2005 Ford F-350 4x4 Service Truck with Crane, VIN # 1FDWX37P55EB97537 (A51572)
2005 Ford F-350...
2015 CHEVROLET SILVERADO CREW CAB TRUCK (A51406)
2015 CHEVROLET...
STOP!!!! PLEASE READ ALL TERMS BEFORE BIDDING!!! UPDATED TERMS!! (A50775)
STOP!!!! PLEASE...
