Hydraulic connectors for 402 FEL
   / Hydraulic connectors for 402 FEL #1
GregWatkins
Harnett County, North Carolina
2k 2710, 1950 Ford 8N
I broke one of the hydraulic connectors (the blue one BTW) on the control valve assmbly of my FEL yesterday. It is where the blue hose connects to the control assembly. The hydraulic connector on top of the threaded connector is what broke. (It got bent and has a hole in it and the hydraulic fluid shoots out when I try to use the FEL.) Is this a "standard" part that may be available from somewhere other then a KUBOTA dealer? If so, I "assume" I can take it to a local place to get a replacement. (closer dealer is about 25 miles from me and I am SURE it will not be cheap :~>) The threaded part is not damaged, just the top where the hose attaches to it.
Any suggestions???
Thanks,
greg
   / Hydraulic connectors for 402 FEL #2
Greg, Meyers snow plow couplers work good as replacements, though you have to replace them as a set.
   / Hydraulic connectors for 402 FEL #3
Whan I had a fitting split open on one of my hoses, I just took the hose off, took it to a local truck shop, and they fabricated a whole new hose. Cost was about $15 I think.
METAL TRAILER FRAME W/ AXLE (A52708)
METAL TRAILER...
Club Car Carryall 2 Electric Utility Cart (A55853)
Club Car Carryall...
THREE POINT ATTACHMENT (A58214)
THREE POINT...
2017 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A55973)
2017 Ford F-550...
2023 Kubota U27-4 Mini Excavator (A55973)
2023 Kubota U27-4...
20FT X 30FT STEEL CARPORT (A58214)
20FT X 30FT STEEL...
