hydraulic circuit, need advise
/ hydraulic circuit, need advise #1
muddstopper
Veteran Member
western NC
Ventrac, Steiner
I am wnating to combine the flow from two hydraulic pumps to make one flow. P1 will provide flow, 30gpm, for one function before combining with P2 flow, also 30gpm to make 60gpm flow for another function. I Plan on running P1 thru a 4way control valve with Power beyond. I realize while operating this control vavle, it will rob oil from my proposed second function that requires the 60gpm of flow, and I am alright with that. I just need to know if I can use the method in the diagram or what changes I would need to make View attachment saw and splitter circuit.pdf.
/ hydraulic circuit, need advise #2
Circuit looks OK.
You can just plug the PB port and the pump flow and cyl flow will pass through the OUT port.
Thanks JJ. being able to combine the flow of 2-30gpm pumps instead of using a 60gpm and a 30gpm will require less HP. The valve has a PB conversion valve I will also have to remove, but no problem there
