Hydraulic Chipper/Shredder Project
   / Hydraulic Chipper/Shredder Project #1
smartguyz
Beaverton, Oregon
JD318, Power-Trac PT425 with scuffed-up green paint.
Hi guys,
It's been a long time. I've been thinking of doing a hydro chipper/shredder project to take advantage of the strong hydralic PTO on my 425.
I may have access to a Mighty Mac Chipper/Shredder as shown here:
MacKissic Inc.
It is intact, but has a dead engine.
I spoke to one of their engineers on the phone, and he said that as long as I put in a powerplant with similar HP and speed, and lined the pulleys up so that it is straight - it should work just fine.
I like this design, because it seems I could mount a hydraulic motor in place of the gas engine, and end up with a hydro chipper!
Here's the question - what size/kind of motor do you think I should get for the 425 to run this, and where's the best place to buy such a beast?
Thanks so much.
-Rob :)
   / Hydraulic Chipper/Shredder Project #2
   / Hydraulic Chipper/Shredder Project #3
The 8 GPM, at 2500 psi for the 425 requires about 14 HP, and when transfered that energy to the hyd motor,and should develop about 11.9 HP.
I am also thinking, that one of the PT owners converted a chipper, or blower awhile back.
J.J.!
Great to hear from you. Thanks for responding. I believe the engineer from Mighty Mac said that the new ones have an 11HP Gross rating. I think that a 14HP would a bit stronger, but would likely work just fine. I don't know what the RPM would be. I would likely need to guess.
-Rob :)
Thanks, I've read that thread. I'm interested in the Mighty Mac 12P primarily for the following reasons:
1) Uses a fractional HP v-belt = automatic safety. If a limb gets stuck, then you will mangle or burn the belt, but it will give you a fighting chance to shut the thing down before something really bad happens.
2) Looks like I can likely mount a hydro motor on the motor mount platform very easily.
-Rob :)
I'm not very good at this. I'm going to guess that a typical engine of that type would have a max RPM of around 2200. It would probably be around an 11-12 HP unit.
So... what kind of hydro motor should I get for this project?
-Rob :)
   / Hydraulic Chipper/Shredder Project #8
Rob, don't break a belt to protect the chipper, put a relief valve in or use the existing one in the PT. That is the beauty of hydraulics, a nondestructive safety. Don't ask me how to do this. Can someone else suggest something.
   / Hydraulic Chipper/Shredder Project #9
You already know that the PT425 main PTO is rated at 8GPM@2500PSI.
You have to determine how many RPMs you want the chipper shaft to turn at.
The hydraulic calculator on the Surplus Center site will take your flow (8gpm) and your desired RPM (3600 or 1800 or whatever you choose) and calculate the size of the hydraulic motor that you need to achieve the desired RPMs. This, of coursed, is based on 1:1 pulleys.
For instance, 8GPM flow and 3600 RPM shaft speed will require a 0.5 cubic inch motor displacement while 8GPM flow and 1800 RPM shaft will require 1.0 cubic inch motor displacement. However, you could change that by gearing system up or down with pulleys.
For instance, lets say your 1" hydraulic motor tuns at 1800RPM and you want to turn the chipper shaft at 3600 RPM. You would need to put a pulley on the chipper shaft that is 1/2 the diameter of the pulley on the hydraulic motor.
So, the question is, what do you need?
A larger displacement hydraulic motor turning at less RPMS geared up with pulleys...
A normal displacement hydraulic motor turning at the same RPMs with no gearing of pulleys....
A smaller displacement hydraulic motor turning at higher RPMS geared down with pulleys....
That is the question I would like the TBN membership at large to answer... should we use a larger displacement motor or a smaller displacement motor? :confused:
   / Hydraulic Chipper/Shredder Project #10
Most of the small engines will turn at to 3600 rpm. If you have the chipper with engine, look at the pulleys and determine if it is 1 : 1, or whatever. That will be the rpm you need for the hyd motor. To protect the hyd motor, a relief valve should be used across the motor.
Determine the shaft rpm of the chipper at max power, I think we know everything else.
Maybe something like this, geared up to match chipper shaft rpm.
https://www.surpluscenter.com/item.asp?UID=3508020416414429&item=981-1025&catname=hydraulic
2016 HAMM HD+ 120i SMOOTH DOUBLE DRUM ROLLER (A51246)
2016 HAMM HD+ 120i...
UNUSED WOLVERINE 66" BOLT ON PALLET FORKS (A51248)
UNUSED WOLVERINE...
2020 PETERBILT 567 DAY CAB (A53426)
2020 PETERBILT 567...
2005 DIVERSIFIED FABRICATORS FERTILIZER SPREADER (A51247)
2005 DIVERSIFIED...
UNUSED FUTURE FT-X1200J STAND ON MUD BUGGY (A51247)
UNUSED FUTURE...
2017 POLARIS RANGER 570 4X4 PROSTAR UTV (A51406)
2017 POLARIS...
