Hydraulic Breaker for Kubota U-25 Mini -Advice needed
   / Hydraulic Breaker for Kubota U-25 Mini -Advice needed #1
flienlow
Snohomish,WA
Kubota BX25D, Kubota U25 Mini Excavator
I am interested in getting a breaker for my Kubota U25. Has anyone been down this road before? Wondering what I should buy or if its even worth it on a mini this small. I have not operated a breaker before so seeking advice.
Thanks.
   / Hydraulic Breaker for Kubota U-25 Mini -Advice needed #2
They like hyd flow and are hard on the machine. Unless you have a lot of work, I'd consider renting a machine for the project at hand and tear up rental equipment instead of yours
Brett
   / Hydraulic Breaker for Kubota U-25 Mini -Advice needed #3
I would agree with rusty. Never used a breaker, but owned a U25. Great mini ex. I think that breaker would break more than the stone and concrete, if you know what I mean.
Interesting read here. I wasnt aware they were that hard on the machines.
   / Hydraulic Breaker for Kubota U-25 Mini -Advice needed #5
I have had a breaker on a KX161-3 and a larger Kobelco. I have seen no ill effects from using the breaker on either machine. When I use the breaker I increase the greasing intervals for the machine. Now it also has to do a lot with the way you run the machine with the breaker, could it do damage, I'm sure, but I'm the only one who runs my equipment when the breaker is on. You also need to realize that a breaker for a U25 will only be around a 300 ft/lb impact class, not sure what you're going to be doing with it or what your expectations are, but it would break some concrete and some stone, but for sure it beats a hand held one...
   / Hydraulic Breaker for Kubota U-25 Mini -Advice needed #6
Just thought I should add this.....obviously if you are just using the machine to hammer 40 hours a week you are more than likely to see some problems, I've hammered for about 24 consecutive days with my bigger machine with apparent problems....let me also also add this, after the first 5 minutes,hammering rock is about as fun as stabbing yourself in the eye.....
   / Hydraulic Breaker for Kubota U-25 Mini -Advice needed #7
The way I've heard it put is that it's better to rent a machine with a breaker then to put a breaker on your own machine...
Aaron Z
GRADALL XL3100IV MOBILE EXCAVATOR (A51406)
GRADALL XL3100IV...
Mitsubishi FG35 Forklift - 8,000lb Lift Capacity, LP Gas (A53473)
Mitsubishi FG35...
2007 Ingersoll Rand P185WJD Towable Diesel Air Compressor (A52377)
2007 Ingersoll...
2015 Freightliner Bucket Truck - Terex TM 100 Boom - Cummins Diesel - Allison Transmission (A53473)
2015 Freightliner...
2025 CFG Industrial MX20R (A50123)
2025 CFG...
2021 VemaTEC 30in Excavator Bucket (A51691)
2021 VemaTEC 30in...
