Fallon
Super Member
Tried to plug the flat face connectors for my PHD in the other day. It was a warm day so I assume heat expanded things & pressurized the lines so they were keeping the QDs from compressing. After 15 minutes I fighting I finally busted out the wrenches & cracked a fitting on the PHD. Turning it off & activating the 3rd function hadn't helped.
Fittings are NPT so they will wear out & are generally a pain.
Does anybody make a small male to female fitting that has a bleed valve or screw on the side to release the pressure? Didn't see anything on Surplus Center that would help offhand. Any other easy recommendations for bleeding off the pressure so you can hook up the QDs?
