Hydraulic AG couplers and heat
   / Hydraulic AG couplers and heat #1
future_vision
New England
DK6010SE HSA
Question. I notice the my ag couplers are leaking on my grapples and at my loader. I've cleaned them up before and tested and didn't se a leak but by the end of a long day running the tractor I am seeing leaks in both locations. Is the heat or the work I am putting them through causing the leak or is it time for some new couplers?
   / Hydraulic AG couplers and heat #2
There is an O-ring in the female half of the coupling that can be replaced to stop external leaks.
Do you happen to know the size o-ring. I believe I have 1/2 ISO couplers?
   / Hydraulic AG couplers and heat #5
The o-ring inside female hyd coupler should be easily obtained at a hyd repair business.
Thanks. I have a pretty big o-ring kit and thought I might find a replacement in there. Of course, the o-ring might not be made of the right material for this application
   / Hydraulic AG couplers and heat #7
You can try these:
For 1/2" ISO 5675 "AG" style couplers:
Size = 117
Durometer = 70A
Material = Buna N
You can try these:
Size = 117
Durometer = 70A
Material = Buna N
Thanks. Do you know what they would be for 3/8 couplers? I found out that my other ones are that size.
   / Hydraulic AG couplers and heat #9
Sorry, I have only checked 1/4" and 1/2" ISO 5675 "AG" style so far.
Not sure what your particular Kioti might use, but many of the Korean tractors use ISO 7241 "A" series.
If you have cheap calipers, o-rings are easy to measure.
Thanks. It's a DK6010SE. And i do have some calipers so I will check. Was hoping to get them ordered without having to take the couplers off but if that is my only option I will do that. I also reached out to the dealer to see if they could tell me but they only replace the entire coupler
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2014 GMC Sierra Pickup Truck (A50323)
2014 GMC Sierra...
2007 Chrysler Pacifica SUV (A51694)
2007 Chrysler...
PALLET OF MILITARY STRAPS (A51248)
PALLET OF MILITARY...
UNUSED HURRICANE STAND ON SKID STEER (A51247)
UNUSED HURRICANE...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A53472)
2012 JOHN DEERE...
