Hydraulic AG couplers and heat
/ Hydraulic AG couplers and heat #1
future_vision
Gold Member
New England
DK6010SE HSA
Question. I notice the my ag couplers are leaking on my grapples and at my loader. I've cleaned them up before and tested and didn't se a leak but by the end of a long day running the tractor I am seeing leaks in both locations. Is the heat or the work I am putting them through causing the leak or is it time for some new couplers?
/ Hydraulic AG couplers and heat #2
There is an O-ring in the female half of the coupling that can be replaced to stop external leaks.
Do you happen to know the size o-ring. I believe I have 1/2 ISO couplers?
/ Hydraulic AG couplers and heat #5
The o-ring inside female hyd coupler should be easily obtained at a hyd repair business.
Thanks. I have a pretty big o-ring kit and thought I might find a replacement in there. Of course, the o-ring might not be made of the right material for this application
/ Hydraulic AG couplers and heat #7
You can try these:
For 1/2" ISO 5675 "AG" style couplers:
Size = 117
Durometer = 70A
Material = Buna N
You can try these:
Size = 117
Durometer = 70A
Material = Buna N
Thanks. Do you know what they would be for 3/8 couplers? I found out that my other ones are that size.
/ Hydraulic AG couplers and heat #9
Sorry, I have only checked 1/4" and 1/2" ISO 5675 "AG" style so far.
Not sure what your particular Kioti might use, but many of the Korean tractors use ISO 7241 "A" series.
If you have cheap calipers, o-rings are easy to measure.
Thanks. It's a DK6010SE. And i do have some calipers so I will check. Was hoping to get them ordered without having to take the couplers off but if that is my only option I will do that. I also reached out to the dealer to see if they could tell me but they only replace the entire coupler
/ Hydraulic AG couplers and heat #11
Be aware your Kioti may not have the iso 5675 pioneer connectors. It may have the iso 7241-A connectors which are similar but are not fully compatible with the AG style 5675 connectors.
Discovered this last year when going through the same issue with leaking connectors and looking for the replacement O rings. And got the numbers off of the female connector and with research discovered that are not the standard 5675 ag connectors. I didn't find replacement O rings for the 7241 that are on my DK45S.
From looking at both connectors the 7241 has longer poppet nipples than 5675. So a 5675 ag connector will not fully open the female valve on the 7241 connectors.
/ Hydraulic AG couplers and heat #12
One doesn't need to remove coupler from tractor to R&R o-ring in orifice that male hyd tips fits into on breakaway coupler. Just R&R o-ring & backup washer if present while coupler remains on your tractor.
Back to my original question. Can hear cause the o-ring failure? I was putting in 8-1 hour days and my tractor wasn't overheating but I noticed the hydraulic cylinders were pretty hot. It wasn't until I was going my 400hr service that I noticed the radiator reservoir was empty. Maybe sense why the hydraulics were so hot. That is what leads to me to the question about hear and o-ring failure. I think there is a connection here.
/ Hydraulic AG couplers and heat #14
Heat can but typically temperature would have to be 250 degrees F or higher before the O-rings would be affected.
Engine temperature should have very little influence on Hydraulic oil temperature unless the radiator antifreeze solution is used to cool hydraulic oil.
UNUSED IRANCH MINI EXCAVATOR QUICK COUPLER (A60432)
UNUSED IRANCH MINI...
2018 WANCO WTSV PORTABLE ARROW BOARD (A60430)
2018 WANCO WTSV...
Cushman Hauler 1200X Golf Cart (A57148)
Cushman Hauler...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A56858)
Pallet of...
2008 CATERPILLAR M322D MOBILE EXCAVATOR (A59823)
2008 CATERPILLAR...
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
