hydraluic oil
   / hydraluic oil #1
hernando
tennessee
dk 4510 kioti and a 450 case track loader
has anyone used [i think its] traveler brand sold at tsc ?? the price is $ 38.95 for 5 gals. that seems to good to be true.. most of the time i just pick up the agco brand at my massey dealer..but the last time i bought any it was $ 59.00 for 5 gals...any thoughts ??? would you use it??? thanks for any help bruce
   / hydraluic oil #2
I am using it now in a L2350 Kubota and a YM2500 Yanmar. Excellent fluid.
   / hydraluic oil #3
Same answer as always, does it meet the specifications for your tractor? If it does, use it. If it doesn't, don't.
   / hydraluic oil #4
My machine has been operating pretty well, but would chatter wehn turning the wheel. When I bought it, the orignal owner had never changed anything beside the engine oil. So I replace the filter last year and new JD fluid. The chatter went away, but came back.
This year I replaced the fluid with some Special 303 by TRC. It was really expensive, but has eleiminated the chatter even with more hours on it than the JD fluid and my hydraulic respose seems crisper.
So price doesn't really equal quality. Either way.
   / hydraluic oil #5
Next time around you might try TRC's UTF Red. It's a great UTF fluid with a tackifier additive to help the oil stick to gears. It's what I use in all my equipment.
   / hydraluic oil #6
If you are refering to the TSC UTF oil, and not the plain R & O hyd oil.. then use.. I use it (UTF) in machines that it carries the specs for.. IE.. My fords and New holland.. etc.
soundguy
   / hydraluic oil #7
DP,
Do you think that the TRC UTF is a better choice that the 303 Special? I saw the specs on the TRC website and it seems that the special was geared towards common sump equipment that shares hydraulic sumps with the final drives. I guess UTF would need to be the same, but the overall list of fluids that the 303 equals looked like a greater range. It was a total shot in the dark for me when I picked it. But my overall performance seems to be much improved.
   / hydraluic oil #8
In the end.. you want an oil that meets your manufacturers oils specs.. etc.. everything else is gravy..
soundguy
   / hydraluic oil #10
Looks pretty good to me?
soundguy
UNUSED JMR 40" HYD ROCK GRAPPLE BUCKET (A54757)
UNUSED JMR 40" HYD...
2018 JLG G9-43A (A47477)
2018 JLG G9-43A...
JOHN DEERE 437E KNUCKLE BOOM LOADER (A52705)
JOHN DEERE 437E...
2008 Dodge Avenger Sedan (A53424)
2008 Dodge Avenger...
2014 UTILITY 4000DX 53FT DRY VAN TRAILER (A54607)
2014 UTILITY...
2016 FREIGHTLINER CASCADIA DAY CAB (A54607)
2016 FREIGHTLINER...
