hydralics 5210
   / hydralics 5210 #1
lbama
jd5210
Have a jd5210 1999 . Change hyd. fluid , filter and cleaned sgreen . After runnibg for 45 min to an hour the lifts become slow , steering jujmps , brekes only work if you pump them up . Need help please and suggestions?
   / hydralics 5210 #2
Welcome to TBN:D
After it's running, check and see if the fluid is foaming. Your symptoms sound like the system is sucking air on the return side, this can often be cause by the filter or screen that is not installed properly. You won't see a leak because there is negative pressure in the return line while the tractor is running.
   / hydralics 5210
Have a jd5210 1999 . Change hyd. fluid , filter and cleaned screen . After runnibg for 45 min to an hour the lifts become slow , steering jujmps , brakes only work if you pump them up . Need help please and suggestions?
Also fluid gets very hot , steamy , fluid feels like it break downs
   / hydralics 5210 #4
OK, there is a blockage I would guess. Do as I stated above and check the filter and screen again.
   / hydralics 5210 #5
Just to clearify what kennyd posted, I am sure he meant that air is getting sucked in on the suction side of pump....that could happen if suction line is restricted, or suction strainer clogged, a poor hose clamp or hole in the hose....
2004 Chevrolet Avalanche Pickup Truck (A53117)
2004 Chevrolet...
2024 Greatbear 72in Vibratory Roller Skid Steer Attachment (A51691)
2024 Greatbear...
2010 Nissan Sentra Sedan (A51694)
2010 Nissan Sentra...
2019 MACK P164T DAYCAB ROAD TRACTOR (A51406)
2019 MACK P164T...
2008 VE 500 BBL FRAC TANK (A53843)
2008 VE 500 BBL...
2025 IR UNUSED Cleanout Bucket (A53117)
2025 IR UNUSED...
