Hydralic Trash Pump - vs PTO
   / Hydralic Trash Pump - vs PTO #2
How much head do you need? The pump in the video isn't pumping with more than a few feet of head, not much work being done.
I would use it to pump over a small dyke -- a few feet in elevation. My discharge hose would need to be 50 feet or so. This clip shows the 4" model pumping in an actual application.
http://www.youtube.com/watch?v=vsYHsbV_yRg&feature=youtube_gdata_player
The other thing is this: my tractor has a safety feature which prevents the PTO from operating unless I am in the seat. A PTO pump would require strapping down the seat like I do when chipping trees. I have power beyond, so the hydraulics are ready to use.
   / Hydralic Trash Pump - vs PTO #4
Can your tractor hydraulics handle this? I'd think there is a lot more power available from the PTO than from the hydraulics.
I see PTO pumps that will run off your tractor that will deliver more water against a lot more head than they show in the video. I don't find any mention of the head in specs for the unit you are linking to.
As for the PTO safety switch, isn't there a way to disable it for standing use? On my JD 870 you just tilt the seat up and lift the switch to the up position.
Terry
   / Hydralic Trash Pump - vs PTO #5
You can do this if you can check the hydraulic flow required by the pump. I would also compare the cost of a dedicated trash pump too. Using a hydraulic drive may be convenient but is less efficient than a pto pump if it isn't going to see much use then it would not matter. If you are planning on pumping a lot of water a separate trash pump would be my choice, I prefer the ones with Honda engines.
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A52748)
2-Row Peanut...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
1987 LANDALL 48ft Hydraulic Slide Axle T/A Drop Deck Trailer (A51692)
1987 LANDALL 48ft...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2019 FREIGHTLINER...
Heavy-Duty Gooseneck Hay Trailer - Built for Large Bale Hauling (A52748)
Heavy-Duty...
