hydralic toplink
   / hydralic toplink #1
case685
Southwest Ont. Canada
Hello
I was wondering if anyone can offer any advice on buying a cylinder for use as a hydralic toplink. My tractor is 60hp and cat. 2.
I was told by a local supplier that excessive pressures can build up in cylinders under load causing seals to rupture and that there would be side load problems also. Obviously though, plenty of people are using them so I'm assuming it must be a case of getting the right size and style of cylinder for my application.
Any thoughts or insights on this greatly appreciated. Thanks. Gerry
   / hydralic toplink #2
The absolute best place to buy your HTL is from CCM. They have cat 1 and cat 2 with the double pilot operated check valves. Call and ask for Mark. He posts here under the screen name CCI.
I have never heard of any of the concerns your dealer is talking about. Maybe Mark can give you some of his expert insight into any issues there may be (if any at all).
You can also take a look at their FAQ as it will answer many of your questions.
Carter & Carter Machinery top links
   / hydralic toplink #3
Does anyone know if CCM has them in stock yet? I thought Feb was the time...
-Brian
   / hydralic toplink #4
He always had cat 2 in stock
   / hydralic toplink #5
case685 said:
Hello
Hi Gerry,
I bought my top link from CCM with the DPOCV and it is the greatest thing since sliced bread. Many guys also buy their own cylinders and don't have the DPOCV on them without problems. So it is very doable.
I think your dealer who told you that stuff is full of BS.
   / hydralic toplink #6
Mine is the CCM as well Cat2. Works very well. Be sure to use 1/4 inch hose to slow it down a little, makes it more controlable. Only had one load where the cylinder would not lift with perhaps 3 to 4,000 lbs and some overhang. No damage at all just would not lift
   / hydralic toplink #7
Hmm. I traded emails with him in early Jan and he said call in Feb.
   / hydralic toplink
Hi Guys Thanks for all the info. Sounds like CCM is the place to go. Getting a hydralic toplink is the first step in my plan to build a quick attach for my 3ph. Now that I'm getting a little older my back is forcing me to use what brains I have attach stuff to the tractor instead of trying to manhandle them into place. Thanks again. Gerry
   / hydralic toplink #10
I called them to get a CAT II link this last winter and was told they didn't have them and didn't have any idea when their supplier would come through on their order. I found it strange that they didn't put notice on their website about not having inventory.
Eric
CUMMINS ENGINE CO. N-855F DSL TIRE PUMP MOTOR (A51406)
CUMMINS ENGINE CO...
Pallet of (4) 10 Lug Misc Wheels (A51573)
Pallet of (4) 10...
JCB 507-42 Telehandler (A51573)
JCB 507-42...
2025 New/Unused Wolverine 48in Skid Steer Trencher (A51573)
2025 New/Unused...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A51573)
(1) HD 24ft Free...
SHOULE RM8080 LOT NUMBER 129 (A53084)
SHOULE RM8080 LOT...
