hydralic top link
/ hydralic top link #1
jwilkes
i ordered a 4720 monday and was wondering which top link to order from ccm i want to get it here before the tractor gets here thank's for the help!
/ hydralic top link #2
Someone will have to measure theirs, but I found mine runs about 19" to 29"
PS this is center to center, a detail that I have not seen published on the CCM site. I like the idea of the JD support bracket in their top and tilt kit but want to see how this works in person...
/ hydralic top link #3
</font><font color="blue" class="small">( Someone will have to measure theirs, but I found mine runs about 19" to 29"
PS this is center to center, a detail that I have not seen published on the CCM site. )</font>
That's strange because for the last few years that info has been right there on the CCM web site. You just haven't understood what you are reading. /forums/images/graemlins/confused.gif
CCM sells 3 different sizes of top links. The measurements are center of pin hole to center of pin hole, retracted and extended. The top links are 16" to 22.5", 18" to 26", and 21" to 32".
You can get by with either of the last two. Most tractors use the middle size as it doesn't have to match your factory top link exactly.
CCM Top Links
/ hydralic top link #4
Sorry, although common sense leans towards center to center, I tend not to make assumptions. There are length specs, but no indication of whether they are overall or senter to center. I have verified via email that they are center to center measurements.
If I missed it somewhere on the page, please let me know where it is.
/ hydralic top link #5
Cylinder lengths, extended and retracted, are always measured and specified as center pin hole to center pin hole unless no end connector is attached. In fact, you mostly see the stroke and retracted length as the measurements usually given.
/ hydralic top link #6
ALL CCM measurements are Center TO Center. All toplinks are stated using this industry standard. If any other length is used it will be stated.
OUTBOARD ENGINE STANDS (A66738)
OUTBOARD ENGINE...
2023 Kubota L4802DT 4WD 48HP Utility Loader Tractor (A66734)
2023 Kubota...
2011 MERTZ BLENDER TRAILER (A67714)
2011 MERTZ BLENDER...
2017 Jeep Grand Cherokee SUV (A66738)
2017 Jeep Grand...
2009 POLAR TANK . (A67714)
2009 POLAR TANK ...
PALLET OF MISC JACKS AND JACK STANDS (A67714)
PALLET OF MISC...
