Hydralic hose question
/ Hydralic hose question #1
JMAC
SE Kansas
JD 4310, MFWD,E HYDRO
Last night I broke the hydralic hose end connection off of my stabilizer arm on my backhoe. /forums/images/graemlins/blush.gif I had a new one made and my question is do I have to do anything special to reinstall? Bleed air out or will it just work out on it own? The only fluid I lost was what was in the hose.
JMAC
/ Hydralic hose question #2
Nope---Just put the hose on---check your fluid level and your ready to go. You might get a little hesitation at first because of the air in the hose but work the cylinder once or twice and you will be in good shape. Im not sure how big your backhoe hose is but tighten the fittings snug but dont overtighten them because you can crack the flange if you get really carried away. Glenn
/ Hydralic hose question #3
One mechanic I know suggests cleaning the inside of the hose prior to installing. His feeling was it's not worth running all the little bits of rubber, wire pieces and other junk (usually get some inside during the cutting process) through the system to the filter. If the hose is small enough, a blast of air from the air compressor will work. Larger hoses might require pouring some hydraulic fluid through them to clean out the junk. I don't know if it really makes a difference, but it doesn't take but a few minutes either.
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
2019 International LT625 Sleeper 48 (A62613)
2019 International...
2020 John Deere 8R280 (A64119)
2020 John Deere...
2006 STERLING ACTERRA CAB & CHASSIS (A60736)
2006 STERLING...
500BBL SKIDDED FRAC TANK (A58214)
500BBL SKIDDED...
2015 FORD F-150 LARIAT CREW CAB TRUCK (A63276)
2015 FORD F-150...
