hydralic couplers
   / hydralic couplers #1
carhartt56
Bronze Member
Desoto , Mo.
KIOTI DK40SE
I havent used my fel since spring , and was in the barn last night and noticed corrosion on the hyd. couplers (male ends) on my fel . My question is , should they be ok with maybe just a clean up with some steel wool , or do I have more troubles to look at . I guess I wiped them off to well after I removed the fel this spring . The cat has had more seat time this summer than me with the drought here . Thanks in advance .
DK40SE
   / hydralic couplers #2
As long as you clean them up and there is nothing sharp you should be ok. The o-rings can seal pretty good.
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
2015 PETERBILT 389 TRI-AXLE MID-ROOF SLEEPER (A52472)
2015 PETERBILT 389...
2013 CAT 950K WHEEL LOADER (A52472)
2013 CAT 950K...
MANLIFT (A52472)
MANLIFT (A52472)
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A52748)
John Deere 5090E...
