Hydaulics
   / Hydaulics #1
Timber man
Ontario
Kubota
3 point hitch on my kubota model m7500dt working fine until I hooked up my snow blower with hadraulic chute.Now 3 point hitch and chute won't work .Help.
   / Hydaulics #2
:welcome:
I don't know your model and I don't do much with equipment on my 3ph but could your blower be too heavy for your rig? I'd disconnect then try the 3ph again to see if it works. Maybe you didn't connect just right - I understand some pto's have to be just so. Good luck and be sure to post your outcome/fix.
KW
   / Hydaulics #3
Explain how you connected the snow blower.
   / Hydaulics
Thanks I solved the problem,the change of cold weather froze the filter so I warmed it up and it started working.
   / Hydaulics #5
If your filter froze, doesn't that indicate water in the fluid?
Perhaps you should change to a fluid better suited to your climate.
   / Hydaulics #6
x2. use the cold climate fluid all year long
BUNDLE OF DOUBLE AXLE FENDER INSERTS (A54756)
BUNDLE OF DOUBLE...
2013 Ford F150 4X4 Pickup Truck (A53422)
2013 Ford F150 4X4...
2016 Ford Explorer AWD SUV (A54815)
2016 Ford Explorer...
Crosley 10ft Hydraulic T/A Dump Trailer (A50322)
Crosley 10ft...
LEEBOY PF1510B ASPHALT PAVER (A51406)
LEEBOY PF1510B...
