hyd valve question
/ hyd valve question #1
rbushmaster
hey all,
just finished log splitter build
i have a prince valve with power beyond as my main splitter valve
then it goes to a old greson valve for log lifter
the log lifter works fine but my splitter cylinder only went out and if i try to reverse it my pressure spikes and stalls the engine
is it possible that the greson valve is closed center?
if so can it be changed? or do i need a new valve
/ hyd valve question #2
Do you have a hose hooked at tank port to tank still on your valve with PB?
You could take the greson valve lines off, and see if you can blow air through it when in center position, if air goes through you will have an open center. ( P line to T line)
/ hyd valve question #3
Does the Prince valve have regen ( regenerative)? Do you know the part # for it? Just to expand what murph asked you, You do have the T or OUT line hooked up to the prince valve?
i think i figured it out
i need to hook up another line from mainvalve {prince} next to the powerbeyond port and "t" it into the 2nd valves return line before filter?
/ hyd valve question #5
Is this a 3pt log splitter or engine driven? If you have two separate valves and one has PB, then you should have two return hoses going to tank, with a tee fitting. The output of the PB should go to the input of the second valve. Did you install the PB sleeve in the PB port?
If the valve is a regem valve, you can not use it wth a two stage pump.
/ hyd valve question #6
How about some pictures and more data?
If you did install the PB sleeve, and did not not remove the tank plug from the first valve, then the fluid had nowhere to go.
engine driven 2 stage barnes pump
installed power beyond plug
hooked up cylinders
from power beyond i fed the 2 nd valve for log lift
hooked up cylinders
out port of 2nd valve to filter then to tank
after i posted i studied the plumbing schematic that came with valve and it appears the first valve has a port next to powerbond that has to go to tank also
thanks for your time
/ hyd valve question #8
:thumbsup:
hooked up cylinders
hooked up cylinders
:thumbsup:
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
HEAVY DUTY MILITARY TENT (A63276)
HEAVY DUTY...
2011 Chevrolet Express 2500 Cargo Van (A64556)
2011 Chevrolet...
YANMAR VIO35-6A EXCAVATOR (A64279)
YANMAR VIO35-6A...
2020 KUBOTA RTV-X1140 UTV (A63276)
2020 KUBOTA...
2003 Freightliner FS65 Thomas School Bus (A64194)
2003 Freightliner...
