Hyd Top Link
   / Hyd Top Link #11
GlueGuy,
I have been thinking about tip and tilt for my B7500. I recall seeing some pictures of a really handsome guy on a B7500, I'm guessing that was you. What are the chances of getting some more pictures of that guy standing off to the side of the tip and tilt? I checked the Gearmore web sight and couldn't find any kits. Do you have any part numbers? Also, now that you have used it a bit is there anything you would do different? Any help will be appreciated, no hurry of coarse.
Thanks
Al
   / Hyd Top Link #12
<font color=blue>The top link is a 2x8 and the side link is a 2x4.</font color=blue>
Just to flaunt my ignorance once again -- is that diameter x stroke (i.e. 2" diameter x 8" stroke)? If not, what exactly do those numbers indicate? /w3tcompact/icons/crazy.gif
   / Hyd Top Link #13
Harv, I'll beat glueguy to the answer. Yes, that's diameter and stroke. The other dimension you have to be concerned with is getting the overall length, collapsed, of the cylinders right for your tractor (they actually measure them from center of pin to center of pin instead of overall length). My top link cylinder was 20" in length, 2" diameter, 8" stroke, but I had an inch cut off each end to make the collapsed length 18". The side link cylinder was 13.5" in length, 2" diameter, and 3.5" stroke, but I added a bracket at the top that increased the collapsed length a couple of inches.
Bird
   / Hyd Top Link #14
GlueBird -
Thanks! /w3tcompact/icons/smile.gif I've been thinking of writing a book about the things I don't know, but the publisher said they don't have that much paper. /w3tcompact/icons/crazy.gif
   / Hyd Top Link #15
Harv, they already wrote the book about the things I don't know. I think they call it the Library of Congress.
Bird
   / Hyd Top Link #16
I've got the part numbers for the kit around here someplace, but I'll have to get back to you on that (I'm at work, waiting for a batch operation to finish, and the "stuff" is at home /w3tcompact/icons/frown.gif).
The GlueGuy
   / Hyd Top Link #17
<font color=blue>I think they call it the Library of Congress</font color=blue>
I think that that's a work in progress, with no estimated time of completion.... /w3tcompact/icons/laugh.gif/w3tcompact/icons/cool.gif
The GlueGuy
   / Hyd Top Link #18
Yeah, I guess it would have to be a work in progress because I'm finding more and more all the time that I don't know./w3tcompact/icons/laugh.gif
Bird
   / Hyd Top Link #19
Al,
<font color=blue>Do you have any part numbers?</font color=blue>
The Top&Tilt kit that's installed on my B7500 is listed as follows on my invoice:
- Gearmore model TT241-2K, 2 spool valve w/hydraulic top & side cylinder
- Gearmore model VB-170-3K ROPS mounted valve bracket assembly
The top cylinder is a 2x8 (2" bore x 8" stroke) with a length of 18". The side cylinder is a 2x4 with a length of 15.3"
The cylinders were measured collapsed center pin to center pin.
Bird,
<font color=blue>finding more and more all the time that I don't know</font color=blue>
That seems to be a might common ailment. In the words of another friend of mine: "There's nothing wrong with my memory, I just don't always get same day service". /w3tcompact/icons/smile.gif
The GlueGuy
   / Hyd Top Link #20
GlueGuy,
Thanks for taking the time. I appreciate it./w3tcompact/icons/smile.gif/w3tcompact/icons/smile.gif
2012 DODGE Grand Caravan (A56859)
2012 DODGE Grand...
Sundowner Rancher Express 20FT Livestock Trailer (A55314)
Sundowner Rancher...
1995 Generac 94A04738-S 125 KW Towable T/A Diesel Generator (A55851)
1995 Generac...
2016 FREIGHTLINER CASCADIA DAYCAB (A53843)
2016 FREIGHTLINER...
2007 Freightliner B2 School Bus (A55852)
2007 Freightliner...
2018 John Deere 5075E MFWD Tractor (A53485)
2018 John Deere...
