HYD steering help 3500 ford
   / HYD steering help 3500 ford #1
DASDAVID
PALM CITY FLORIDA
TN55
Greetings, I recently purchased a 71 Ford 3500, so far it's been a great find and am looking forward to using it but I am having steering issues. Has anyone taken apart the steering cylinder?
I have the cylinder off and apart as far as the front clip,seal,and 2 washers but don't know how to get the shaft out, anyone?
   / HYD steering help 3500 ford #2
Not sure if you already fixed it or not. If it's a single cylinder, on the left side, that pulls on a pitman arm attached to the axle....That cylinder has to be cut open on a lathe, re-packed and welded closed. I had one done a month ago. I was going to do it myself but I went camping instead. I paid the $306 at the hydraulic shop and had it back by the time I got home. I saved a lot of money by cleaning everything and having it disassembled and ready to go for them.
Thanks for the reply, I tried to fix it not knowing the thing had to be cut??? I did however replace the outer seals by prying and such,(no fun either) I do still think it leaks but steers fine. I will someday pull it off again and take it to a hyd shop I do business with , after I talk $ with them. thanks again.
2018 Chevrolet Tahoe SUV (A50324)
2018 Chevrolet...
2004 Hydraulic Breaker Excavator Attachment (A49461)
2004 Hydraulic...
PHENIX TECH HI POT MACHINE (A50854)
PHENIX TECH HI POT...
2014 Therm Dynamics TD400 Towable Flameless Heater Trailer (A49461)
2014 Therm...
1999 Ford F450 Dump / Plow Truck (A50514)
1999 Ford F450...
SHOP MADE  MANIFOLD TRAILER (A50854)
SHOP MADE...
