hyd.shuttle shift / ever clutch difference
   / hyd.shuttle shift / ever clutch difference #1
47sawdust
worcester vt
kubota m-4000,kubota l2550
I have an L3750 with a hyd. ss that is clutchless to operate from forward to reverse.
My question is-does the ever clutch operate in the same manner?
I've seen reference to a momentary clutch operation between forward and reverse with models so equipped.
   / hyd.shuttle shift / ever clutch difference #2
Don't know but all Kubota Hydraulic shuttles have multiplate wet clutches in the main gear cases and no dry clutch in the bell housing. Just a damper plate.
I have 2 of them.
I am confused only about the ever clutch on the L4350,4850, and 5450 models.The operators manual says the clutch pedal needs to be momentarily engaged before shifting.
My 3750 does not need the clutch pedal engaged. I just come to stop and shift to change direction
   / hyd.shuttle shift / ever clutch difference #4
My owners manual covers L4350, L4850, and L5450. It is a 2004 re print from the kubota dealer. It is a spiral bound book. My book says "Shift the shuttle lever forward to obtain forward speeds and shift it backwards to obtain reverse speeds without using the clutch pedal."
   / hyd.shuttle shift / ever clutch difference #5
I believe you mean disengaged not engaged.
geneP- Thanks that is what I was looking for.
5030- You are correct
   / hyd.shuttle shift / ever clutch difference #7
I'm not fond of anything that has a dry clutch. The dry clutch will always be the weak point and always a royal PITA to replace, whereas a wet pack travelling clutch rarely fails. They do but not often
2017 Ford F-150 Ext. Cab Pickup Truck (A50323)
2017 Ford F-150...
Swict 66" Skidloader Bucket (A50774)
Swict 66"...
2012 Cadillac SRX SUV (A50324)
2012 Cadillac SRX...
2018 International WorkStar 7400 T/A Dump Truck (A50323)
2018 International...
2014 Ford F-250 Extended Cab Knapheide Service Truck (A50323)
2014 Ford F-250...
DROME EXCAVATOR SLIDE ATTEHMENT (A50322)
DROME EXCAVATOR...
