Hyd. Questions for Grapple on 3510HST
   / Hyd. Questions for Grapple on 3510HST #1
swampyankee
Maine
3510 HST
Can anyone tell me how to hook up a hyd. valve to run a grapple on the bucket. Can I just T off the bucket valve to an other valve to run the grapple? Thanks /forums/images/graemlins/confused.gif
   / Hyd. Questions for Grapple on 3510HST #2
You can run lines from you rear remote to the front.
If you are using your remotes already then you will have to take other measures such as a electronic third function or get a valve and tap into the plumbing on your loader valve.
   / Hyd. Questions for Grapple on 3510HST #3
Swanpyankee, You will be needing a 2 way, single spool valve with a power beyond sleeve. You will have to take your power off from the power beyond port on your loader valve. and then feed your 3 point hitch from the power beyond sleeve on your grapple valve. Being I am not real computer savy, give me a call at 585-343-0770 and I will go over it in detail with you. Please call me before you try to do this because you can do some very costly damage if it is hooked up wrong.
Galen LaWall
Your Mahindra Tractor Dealer
Batavia, NY
Thanks for the input. My dealer here in Maine has not hooked a grapple up before so I thought I would help him with some info. If you don't mind I will have him call you since he is going to do the work. He is about hyd. I made the grapple and was going to let him hook it up.
Thanks John Green
2016 Chevrolet Sonic LS Hatchback (A50324)
2016 Chevrolet...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2011 Ford Utility Econoline Van (A50515)
2011 Ford Utility...
Woods F21D Zero Turn Mower (A50514)
Woods F21D Zero...
2017 RAM PROMASTER 2500 CARGO VAN (A51222)
2017 RAM PROMASTER...
2017 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2017 GENIE GTH-636...
