Hyd. Pressure
/ Hyd. Pressure
I have a 55 gallon drum that I converted into a counterweight (filled with concrete) that should be approx 1100 lbs with all the metal in it. I can get that without a problem, but I am unable to lift a pallet of wood pellets (2400#'s). I need to get a couple of items with know weights from 1500 to 2000 lbs and see where I am maxing out at.
/ Hyd. Pressure #32
pontiacman,
When you try to pick up a pallet of wood pellets, how far away is the back edge of the pallet, from the pin line. Are you lifting the pallet with forks only, or bucket mounted forks?
/ Hyd. Pressure
I am using pallet forks (SS style quick attach), so the pins are as close to the load as is physically possible.
/ Hyd. Pressure #34
Where did you measure the pressure? I realize that pressure is pressure but if you have a restriction after the valve (in the qc's for example) that might cause some problems. This might be reaching but something has too be wrong - or as J_J stated - you are expecting too much from it.:confused:
Do you have a gravel or sand pile? you might be able to create a known test load from that based on volume.
/ Hyd. Pressure #35
It is not what he expect, is the loss of ability to lift the limit stated by Montana. His machine has a lift Capacity = 2,385lbs at the set relief pressure. .
/ Hyd. Pressure
I measured the pressure at the quick connects for the loader(under the cab).
I do have a couple of dirt piles, but I will not be able to get into them until spring. During past dirt moving, the loader will handle a heaping load of dirt, but I can get into a pile where I am unable to lift or curl. With a heaping pile of dirt, the back end is very light without some ballast.
/ Hyd. Pressure #37
Your 2500 lift is probably rated at the pins. Id think your forks weigh 3-400lbs and their center of mass is at least a foot from the pins. Then add the 1500lbs with CM about 3 or more feet from the pins and the accumulated 1800+ lbs is just over the limit. Im not surprised. ... I would raise the relief pressure to 2500. Most tractors are set around that.
larry
2013 Dodge Charger Sedan (A59231)
2013 Dodge Charger...
2007 JLG 600S TELESCOPIC BOOM LIFT (A62129)
2007 JLG 600S...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A62129)
KNOW BEFORE YOU...
1986 MURRAY WEST COAST STYLE RGN (A60736)
1986 MURRAY WEST...
2017 CHEVROLET SUBURBAN(INOPERABLE) (A60736)
2017 CHEVROLET...
Giyi GY-CW59 (A60463)
