desert trader
Is 303 hyd oil a good oil to use and can galvanized pipe fittings be use in plumbing in a hyd system such as tees an elbows on the pressure side.
Are you talking about John Deere 303 oil? If yes it is a good product.
NEVER use galavanized pipe fittings for hydraulics. The galvanizing is eaten off the inside of the pipes and then plugs or destroys all of the other components in the system.
Standard schedule 40 pipe in general is not strong enough to with stand the pressure of most hydraulic systems.
example: 1/2" & 3/4' schedule 40 threaded connections are only rated to 650 PSI
Roy
I got alot of antiques that use black iron fittings.. but really.. any time I repalce anything.. I remove them.. they truly aren't rated for it.. etc.
soundguy
seen a water sphigot use too!
soundguy
