Hyd. oil filter failure on FX model
   / Hyd. oil filter failure on FX model #1
YanmarFever
Elite Member
Eating a melon..
Mahindra 5010C- Branson 4520r- 5520C- Yanmar FX235-D - Bad Boy rogue mower
I had a hyd. oil filter failure on FX model, I was using the wix 7401 for 5 years. Then whamo I had 2 of them fail on an Fx24. The loader wont even go up, then when I put the old yanmar filter on it works.
What hydraulic filter do you use on your FX models /forums/images/graemlins/confused.gif
Ernie
   / Hyd. oil filter failure on FX model #2
Ernie, you have mail
Buck
   / Hyd. oil filter failure on FX model #4
How does the filter fail? Does it burst?
   / Hyd. oil filter failure on FX model #5
Ernie,
Napa 1229, Wix 51229, Fram P7061, or Baldwin BT371-MPG are the numbers I have, although we have used the Baldwin exclusively for the last 3 years.
If your filter is clogging, maybe it isn't failing, just doing it's job? Of course if there was that much crud in the system you would surely know it.
Let us know what you figure out, your opinion and experience is valued.
   / Hyd. oil filter failure on FX model #6
I use a wix 51205. It is wire mesh, not paper like the 51229 and 7401. It crosses to the CAPA filters that come on the tractors from Japan.
1986 ASPT 30ft S/A Pole Trailer (A51692)
1986 ASPT 30ft S/A...
2006 Ford Explorer 4x4 SUV (A51694)
2006 Ford Explorer...
Soosan 140 Hammer 30 ton Class (A52384)
Soosan 140 Hammer...
JOHN DEERE 5125R (A53084)
JOHN DEERE 5125R...
UNUSED FUTURE XJ3T 3TON 30" HYD THUMB CLAMP (A51248)
UNUSED FUTURE XJ3T...
1267 (A50490)
1267 (A50490)
