hyd leak
/ hyd leak #1
kurtga
N. Georgia
1995 kubota L2350 1999 Bobcat 553 2004 Bobcat S130
I have a 199? L2350DT with a LB400 loader. Today the loader did not want to work when the joystick was moved to the "down" position. All other positions worked (dump, down, roll back, etc.). I also noticed a small leak of hydraulic fluid coming from the bottom of the hydraulic unit in the area where the hoses attach. There are 3 or 4 small Allen head screws where the leak is coming from. The amount of fluid leaked was about enough to fill a bottle cap. Is there anything I can look for to make my bucket dump and repair the leak before I have to take it to the local mechanic? Any help is appreciated. As a relatively new tractor owner, I have learned many new things on this forum.......thanks in advance for any advice...kurt in georgia
/ hyd leak #2
Have you try to tighten the screws also check your hydraulic fluid level.
Thomas..NH /w3tcompact/icons/wink.gif
12ft. 24 Gauge R Panels (A65640)
12ft. 24 Gauge R...
20ft Bi-Parting Gates (A65583)
20ft Bi-Parting...
Kubota Zero Turn Lawnmower (A65579)
Kubota Zero Turn...
2011 Ford F250 Super Duty Lariat (A66408)
2011 Ford F250...
Case IH 820 Rigid Grain Platform (A66408)
Case IH 820 Rigid...
40ft High Cube Shipping Container (A65583)
40ft High Cube...
