hyd leak
   / hyd leak #1
kurtga
N. Georgia
1995 kubota L2350 1999 Bobcat 553 2004 Bobcat S130
I have a 199? L2350DT with a LB400 loader. Today the loader did not want to work when the joystick was moved to the "down" position. All other positions worked (dump, down, roll back, etc.). I also noticed a small leak of hydraulic fluid coming from the bottom of the hydraulic unit in the area where the hoses attach. There are 3 or 4 small Allen head screws where the leak is coming from. The amount of fluid leaked was about enough to fill a bottle cap. Is there anything I can look for to make my bucket dump and repair the leak before I have to take it to the local mechanic? Any help is appreciated. As a relatively new tractor owner, I have learned many new things on this forum.......thanks in advance for any advice...kurt in georgia
   / hyd leak #2
Have you try to tighten the screws also check your hydraulic fluid level.
Thomas..NH /w3tcompact/icons/wink.gif
Root Grapple (A50322)
2018 JOHN DEERE 333G SKID STEER (A51242)
2018 JOHN DEERE...
2012 Volvo XC70 Wagon (A50324)
2012 Volvo XC70...
2019 KENWORTH T680 SLEEPER (A52577)
2019 KENWORTH T680...
FELLA TH800 HAY TEDDER (A51243)
FELLA TH800 HAY...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A52128)
2016 Ford F550 4x4...
