hyd hose from implement to tractor almost impossible to hook up
   / hyd hose from implement to tractor almost impossible to hook up #1
cowboy11
homewood
5420/5525 john deer 6610 ford 3910 ford
has anyone found the solution for difficult hook up from implement to rear hyd's I have tried bleeding the pressure
this does not help does john deere have a different quick coupler that will hook up without trying your patients
also if you get it to connect it is hard to disconnect need help:confused:
   / hyd hose from implement to tractor almost impossible to hook up #2
Most times it is just the pressure, many times on the implement side. When I relieve the pressure into a rag, they pop in easy. Lots of times on the implement side I just wrap the connector with a rag and push the tip in against the frame. I have also had times the pressure was so great, I couldn't simply push it, I had to hold it against something hard like the frame and hit the back side with my hand. If there is any pressure on the tractor side, I generally shut the tractor off and move the rear hydraulic control lever both directions a couple times.
2004 TerraGator 8104 (A53473)
2004 TerraGator...
2002 VOLVO L150E WHEEL LOADER (A51246)
2002 VOLVO L150E...
ASSET DESCRIPTIONS & CONDITION (A53426)
ASSET DESCRIPTIONS...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2008 CATERPILLAR 325DL Long Reach (A52384)
2008 CATERPILLAR...
