Hyd hook up
   / Hyd hook up #1
sokoj
To JJ and kend. If I run a hose from the outlet port of the FEL control to the inlet port of the log splitter control(LSC) and then run a hose from the out let port of the LSC and connect it to the hose removed from the FEL control, will it work. I would adjust the pressure relief on the LSC if it has one to around 1700 PSI as that is what most snow plows operate on .
   / Hyd hook up #2
Yes it will work, if it is an open center valve. If that valve is a used valve, you really don't know if the work ports are not leaking, and if it will lift and maintain the blade height. If it drifts down at 30 mph, I think it will get your attention. Are you trying to adjust both the angle and tilt?
   / Hyd hook up
To JJ. Will only us the LSC for left and right angle of plow. It is mounted in the bucket of my Kioti. I assume my FEL contrrol will still work for raise and lower of the plow also. Am I correct ??
   / Hyd hook up #4
Yes. The FEL will have priority over the other valve. If you are not using the FEL, you can operate the plow.
   / Hyd hook up
Thanks JJ and kend. Will send pictures when complete. Weather here nice now but better get off my duff and start on this project soon or I will be doing it in the cold rain,sleet or snow ! Thanks
2022 PETERBILT 389 MID-ROOF SLEEPER (A52472)
2022 PETERBILT 389...
Kawasaki NR (A50324)
1977 CATERPILLAR D6D (A52472)
1977 CATERPILLAR...
New Holland Boomer 55 Tractor (A52384)
New Holland Boomer...
JOHN DEERE 1705/6700 (A53084)
JOHN DEERE...
2008 Ford Crown Victoria Sedan (A51694)
2008 Ford Crown...
