Hyd filter housing 3510
/ Hyd filter housing 3510 #1
Jeffery8mm
Mississippi
Got on a stump yesterday:mad:. I am in need of the part that the hydro filter screws to. How much is this mistake gonna set me back???
I assume this is gonna be a dealer item??
Also, has anyone been able to cross reference the OEM hyd filter to a Wix??
Thanks
Jeff
/ Hyd filter housing 3510 #2
Ouch. Dunno how much it is gonna run you but I'd go to wallacetractor.com and see if they have it in stock. I think Mike works in the shop and could probably tell you what you need.
/ Hyd filter housing 3510 #3
the 3510 should have the same filter as my 2810. NAPA should have it in their listings. Donaldson #169078 Napa# 1586. The NAPA actually is made by Donaldson. Hope the stump did not do much damage. GOOD LUCK
Looks like the filter housing is gonna tear up a Ben Franklin. Not as bad as I had thought!!
Jeff
/ Hyd filter housing 3510 #5
My 4110 has one of those huge canisters and filters under the tractor. I'm considering checking into some type of spin on filter conversion the next time I need to change the filter. The rubber hoses on each end of the canister tend to break down.
STIHL HT250 POLE SAW (A64276)
STIHL HT250 POLE...
2018 Caterpillar 287D Two Speed Compact Track Loader Skid Steer (A64553)
2018 Caterpillar...
Welcome to the Ranch Metal Sign (A65583)
Welcome to the...
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A64556)
2022 Peterbilt 567...
2005 International 5900i T/A Gardner Denver Kill Truck (A64194)
2005 International...
2015 Kenworth T880 QMC 8060R 40 Ton Tri Axle Straight Boom Crane Truck (A64194)
2015 Kenworth T880...
