Hyd filter housing 3510
   / Hyd filter housing 3510 #1
Jeffery8mm
Mississippi
Got on a stump yesterday:mad:. I am in need of the part that the hydro filter screws to. How much is this mistake gonna set me back???
I assume this is gonna be a dealer item??
Also, has anyone been able to cross reference the OEM hyd filter to a Wix??
Jeff
   / Hyd filter housing 3510 #2
Ouch. Dunno how much it is gonna run you but I'd go to wallacetractor.com and see if they have it in stock. I think Mike works in the shop and could probably tell you what you need.
   / Hyd filter housing 3510 #3
the 3510 should have the same filter as my 2810. NAPA should have it in their listings. Donaldson #169078 Napa# 1586. The NAPA actually is made by Donaldson. Hope the stump did not do much damage. GOOD LUCK
Looks like the filter housing is gonna tear up a Ben Franklin. Not as bad as I had thought!!
Jeff
   / Hyd filter housing 3510 #5
My 4110 has one of those huge canisters and filters under the tractor. I'm considering checking into some type of spin on filter conversion the next time I need to change the filter. The rubber hoses on each end of the canister tend to break down.
   / Hyd filter housing 3510 #6
The later 4110's used the same spin on filters as the 3510's.
Unused 2025 CFG QK16R Mini Excavator (A50322)
Unused 2025 CFG...
CFG Industrial QK20R (A47384)
CFG Industrial...
Adams FL24 Fertilizer Conveyor - 24IN Belt, Predator Engine, 2IN Hitch, Refurbished by Manufacturer (A52748)
Adams FL24...
2201 (A51691)
2201 (A51691)
CAT Skid Steer (A50322)
CAT Skid Steer...
