HY/TRANS
   / HY/TRANS #1
sniper_moore
What type of hy/trans fluid do most of you use and could someone tell me the capacity of the Hy/trans system of a YM2000? Thanks Ken
   / HY/TRANS #2
Any Hy/tran fluid compatible with the JD 303 standard. I use John Deere fluids cause JD used Yanmar engines and I figuere the stuff they recomend for their engines would work in mine. I have been thinking about synthetic hy/tran fluid like Amsoil. It sounds like it would improve winter powershift performance.
Chris
   / HY/TRANS #3
I started a thread with little response about this. I have seen Tf300 spec on some tractors and TF 500 on others. I still would like to know if JD 303 will replace both or if there is two different types. My YM1820 with powersteering whines since I put the new JD303 fluid in it.
   / HY/TRANS #4
Reed, if you just changed the fluid, you may have air in the system and need to bleed it. On a car you would jack up the front wheels,and, engine off, turn the wheels back and forth several times, without bottoming, to purge the air. I imagine a tractor is similar.
Norm
   / HY/TRANS #5
Reed, what kind of power steering has that 1820 got? Do they all come that way or is it aftermarket?
   / HY/TRANS #6
I assume it is stock. It is totally contained in the steering box,(no external cylinder). There is only a block under the hood to divert flow from the pump. It uses the same pump as the lift. I have seen a Mitsubishi with a unit like this.
2000 WINNEBAGO FORD F550 RV (A52472)
2000 WINNEBAGO...
2010 Chevrolet Malibu Passenger Car (A51694)
2010 Chevrolet...
2016 Ford F-550 Palfinger PSC3216 4,000LB Crane Service Truck (A51692)
2016 Ford F-550...
2019 GEHL RT105 SKID STEER (A51246)
2019 GEHL RT105...
2018 Dodge Ram 3500 4x4 Utility Flatbed Truck - HEMI Gas, Gooseneck Hitch, Southern Truck (A52748)
2018 Dodge Ram...
