hy/tran oil. 10/-20 or 10-30 weight , is there much difference
   / hy/tran oil. 10/-20 or 10-30 weight , is there much difference #1
coffeeman
Platinum Member
Hi all
just saw it offered both ways. Sam's club had House brand at 10=20. TSC had Traveler at 10=30. Is heavier better? price is close by 2 bucks. I have Mahindra 4110.
Cheers............Coffeeman
   / hy/tran oil. 10/-20 or 10-30 weight , is there much difference #2
Depends on your climate and use. If u r north then the 10-20w is probably fine. Otherwise go with the 10-30w. I know folks have either loved or hated the TSC.
On the 4110 I'm not sure what the manual says as I have a 1538- take my advice with a grain of salt!!!
   / hy/tran oil. 10/-20 or 10-30 weight , is there much difference #3
I don't buy by weight. I get by specs. About all have the same specs except for the real cheap stuff like the 303 which was made for old tractors and older spec levels. I use the TSC premium and have had no issues even at -10F.
Thanks for both replies. I have a Mahindra 4110, 2002 or close. The operator's manual "recommended grade" THF 500. I will use the 10-30. Don't use in real cold weather. A wild card, I have a leak transmission fluid. The tractor was split in half 3 seasons ago. Had to replace a power-take-off gear. when put back together all fine. the next season started seeping oil. but hardly noticed on dip stick. This season leaking faster. I believe it's time to crawl under & check it out.
Happy Father's Day to all the Dads out there. Cheers....Coffeeman
9202 (A50322)
9202 (A50322)
Electric Concrete Mixer (A51573)
Electric Concrete...
Modine Shop Heater (A51573)
Modine Shop Heater...
2024 New Holland T8.410 MFWD Tractor (A53472)
2024 New Holland...
2012 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Versalift SST40 Boom (A53472)
2012 RAM 5500...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
