Hy-Gard Turned Blue
   / Hy-Gard Turned Blue
I think it means your tractor is pregnant...:D
That's the one that makes the most sense. I had both buckets outside side by side, so there is no disputing the color. I was going to finish off the old bucket before opening the new. I will have to take a picture of it.
   / Hy-Gard Turned Blue #12
I would pour some in transparent containers to get a better look at it. Is there water or other junk in the bottom of the pail? Do you see floating stuff in the oil while holding a light behind it? Does it look pure or mixed?
   / Hy-Gard Turned Blue #13
Did you break the seal to open the bucket, or was it opened previously? Could it have been refilled with used fluid, either by you (and you forgot) or by someone else (and they returned a bucket of used fluid for a refund and you bought it)?
Case Ih 1660 Combine (A50514)
Case Ih 1660...
Heavy-Duty Gooseneck Hay Trailer - Built for Large Bale Hauling (A51039)
Heavy-Duty...
2016 FREIGHTLINER CASCADIA TANDEM AXLE 6X4 MID ROOF SLEEPER TRUCK (A51219)
2016 FREIGHTLINER...
2021 Exmark Lazer Z 60in Zero Turn Commercial Mower (A49461)
2021 Exmark Lazer...
2019 RBR Venturi 380 (A51039)
2019 RBR Venturi...
2018 VOLVO VNL64T670 TANDEM AXLE SLEEPER (A51219)
2018 VOLVO...
