HVAC thermostats
   / HVAC thermostats #11
You can buy programmable thermostats though Grainger for approx. $100-$150 that are password/PIN protected and do not allow one to move the temperature above preset maximums for heat and minimums for AC. I believe the RobertShaw line has thermostats with this feature. Check their website - the user manuals are online.
Joe
   / HVAC thermostats #12
BTW - some of the thermostats also let you set the duration of temporary over-rides (i.e. number of hours before program settings are resumed). The RobertShaw that I have defaults to 3 hours (but I believe can be set to something different).
Joe
   / HVAC thermostats #13
We had the same issue with the air conditioning at our Fire House
I put a thermostat hidden some place set with lowest setting you want to see.
wire in parallel to the original.
Then put a wind up timer/switch beside the original thermostat for the on time wired in series with that thermostat.
when some one winds up timer it will connect higher setting to heater for the given time then revert back to freeze protection temperature.
tommu56
2021 International HV507 4x4 12ft Single Axle Dump Truck (A54814)
2021 International...
JOHN DEERE 8R 280 (A53084)
JOHN DEERE 8R 280...
2008 FORD F-150XL TRITON TRUCK (A54756)
2008 FORD F-150XL...
20pc 4ft. x 3ft. Yellow Metal Diamond Plate (A55758)
20pc 4ft. x 3ft...
2019 Doosan LCV6W Towable LED Light Tower (A51691)
2019 Doosan LCV6W...
2012 Dodge Ram 1500 Tradesman Crew Cab Pickup Truck (A53422)
2012 Dodge Ram...
