HVAC in the attic?
   / HVAC in the attic? #11
Bleach??? On the drip pan (plastic or metal) under A-coil or in the drain line pump? I put bleach in the condensate pump or use the tablets that they sell.
   / HVAC in the attic? #14
I doubt they will enforce anything on the new units and if they did/do; they will have a lead-in time of several months. Are they could to go around to millions of homes and check? I do not think so.
The cost will double for the end customer but I doubt it will be 2X for the distributor. My old-man friends ownes several HVAC business and that is where I get/got allmy stuff. The mark up is a total junk. It is #3 on my list below siding (#1) and underground sprinklers is a close #2.
   / HVAC in the attic? #15
</font><font color="blue" class="small">( bad link junk.... )</font>
Fixed.... works for me... /forums/images/graemlins/grin.gif
   / HVAC in the attic? #16
</font><font color="blue" class="small">( Bleach??? On the drip pan (plastic or metal) under A-coil or in the drain line pump? I put bleach in the condensate pump or use the tablets that they sell. )</font>
Mike,
I disconnect the pipe from the air handler and only put bleach in the PVC pipe that's leaving.
   / HVAC in the attic? #17
do the same thing. I also use it everyday (condensate pump) for Ro/DI waste water....:)
Pumps lots of water per day..around 30 to 35 gallons.
   / HVAC in the attic? #18
In the link, a person states "replacing an average SEER 10 central air conditioner costs $2,500 to $3,500." What does that include since it seems very high.
   / HVAC in the attic? #19
The latest home we bought was all electric. I had it converted over to forced hot water,. For the second floor, the only option was to place an air handler in the attic. This, is after I installed a pull down stair case in an unused bedroom. At that, the air handler hardly made it up and through. It has heat and A/C lines to this handler and two drains that go outside.. Best move we ever made.Just finishing it's second year, this September. Best move we ever made. Condensor is almost a hundred feet away. All works well and I would do it all over again if I have to.
   / HVAC in the attic? #20
I have a 2 zone, 2 system installation. The second floor air handler is in the attic, and has been for 17 years w/o problem. It is a very common practice with 2 story 2 zone systems. The only precautions on doing it are: be sure all ducting in the attic space is well insulated (newer, higher insulation standards are now in effect); be sure that there is a secondary drip pan under the unit, with a separate drain and/or shutoff float switch; and try to provide as good as possible access for service and PM.
paul
1999 CHEVROLET C7500 UTILITY TRUCK (A56129)
1999 CHEVROLET...
2017 Ford F-150 XL (A53314)
2017 Ford F-150 XL...
2018 FORREST RIVER CRUISE LITE CAMPER (A53843)
2018 FORREST RIVER...
1981 LOAD KING BELLY DUMP (A53843)
1981 LOAD KING...
Two Post Car Lift (A50120)
Two Post Car Lift...
Gooseneck Livestock Stock Trailer - Tandem Axle Ranch Hauler - Selling Absolute, No Reserve (A55301)
Gooseneck...
